AB ML1400 1766-L32BXBA Ser A
srhair72
Feb 2021
New York
Hello all, I'm just starting out programming and having an issue. Is there any way to get a floating point data file into a string data file within the AB ML1400 1766-L32BXBA Ser A? Thank you in advance.
Workwork or homework?
Welcome to the forum.
From the ref. manual (https://literature.rockwellautomati...documents/rm/1766-rm001_-en-p.pdf#G25.1083291) I don't see any float conversion to string, but there is a integer conversion to string instruction AIC; that could be made to work, if clumsily.
ml1400 (1766 L32BXB) problems with communicacion ascii I configured the channel 2 like ascii, 9600 baudios, parity none, stop bit 1 , data bit 1...
1,803
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
503
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,449
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,230
Hi, I've got a new project for a vacuum conveying system. We require to add another HMI to the existing system which will then feed 2 separate...
1,836
