ml1400 (1766 L32BXB) problems with communicacion ascii
JAELICON
Mar 2017
Monterrey
I configured the channel 2 like ascii, 9600 baudios, parity none, stop bit 1 , data bit 1, i used the blocks AWA, AWT,ACB,ACL,ABL in order to send information but i cant see anything in the channel status.
Somebody can help me?
Hello all, I'm just starting out programming and having an issue. Is there any way to get a floating point data file into a string data file...
917
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
503
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,448
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,230
Hi, I've got a new project for a vacuum conveying system. We require to add another HMI to the existing system which will then feed 2 separate...
1,836
