AB [OSR] Bit Usage?
ndzied1
Aug 2002
Chicago, Illinois
2,857
I had always thought that you weren't supposed to use the bit for an OSR instruction elswhere in a program.
Then I'm reading AB's manual for the HSCE2 (pub 1746-UM002A-US-P) and see the following construct on page 6-17:
B3:0/0 B3:0/6 B3:0/4 B3:0/7 O:1/17
------] [-------] [---------]/[------[OSR]--------(L)------
B3:0/7 O:1/17
In the RSLogix help for SLC instructions, it says that the bit value of for the OSR is where the previous state of the rung is retained. This is misleading at best.
Could it be that as long as the conditions preceeding the OSR are still true, the Bit will be a 1? Sort of like a middle of the rung output????
You are probably right, but I wouldn't count on it. I only us ethem once. The programming examples in the various manuals are "shaky" at best. They seldom work as written. Good luck. If the example were right, you could simply use an ote instead of an otl on the first rung to acccomplish the result of the second.
osr
Yes, the bit still at 1 as long as the rung goes fals.
I try it in a plc5 and it's working. You can programed in this way but, you must make a good description.
I think, is a bad way to program.
For me, a OSR is a OSR. I use it only as osr.
Just wondering if i can make my code look a little nicer and sharing storage bits like below https://imgur.com/a/SMNxOPu does this work or does...
1,585
studio 5000 and compact i have an int that is a 1 second increment for something when a change in the int happens regardless of up or down i...
1,974
Hi folks, first post so be kind. I'm adding a vision inspection system to a toggle press and in the toggle press program they are using an OSR...
2,249
Hi all, Just a quick question my co-worker has said using the same OSR twice is bad practice in the following bit of code could you please...
32
13,562
Hi all. Simple as simple can be, I don't understand what's happening. I'm toggling he OSR on, GX_LUB_PUMP1_LEAD should switch. It doesn't. The...
27
675
