AB PLC 5/40-E OPC Comm Issue
ahnerrj
May 2010
Hamilton
We have a small number of PI3 tags configured to read a 5/40-E. The tags read "Bad" in PI. When I use a PI (OSI product) OPC monitoring tool to read the tags which by-passes the PI3 system (interface node), I receive a "Bad-00000000" value for quality. Therefore, I don't believe the problem lies with PI. We experienced a mill wide power outage which most likely caused this problem. The configuration on the PI communication node was never changed (the tags read bad on startup).
Is there an OPC component in the PLC that could cause this problem? I can ping the PLC from the OPC interface node, and the PI interface software starts up and connects with no errors. I can also use RSLinx from the interface node to read good data from the integer registers. It seems the PI system is rejecting the data it receives.
Any ideas???
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
226
I hope this isn't an obvious question but can any AB PLC talk OPC such that it could read and write directly to Kepware (or IGS) system tags? OR...
2,711
Hi, I have a multiple PLCs (AB) running multiple applications, inc Motion, on different VLANS, but connected via Stratix5700 (CGN) switches and...
2,468
A CIP request for the Identity class (0x01), Instance (0x01), yields the State in Attribute 8 (0x03 as Operational, for eg.) in its response. Is...
473
Hello, im new to this PLC World, im a student currently in an internship, my boss wanted to know if i knew if there is any way to extract data...
1,954
