AB PLC 5/60 DH+ Problem
WhatThe
Nov 2003
I have a AB PLC 5/60 with both DH+ channels being used. Every time you communicate on the 9pin DH+ via PCMK card and RSLinx, you can get online and make changes but when you go off-line, the processor quits communication on all DH+ channels. The HMI devices throw errors like "PLC failed to respond". If you cycle power communications are resumed, and the processor can be seen on RSLinx as active.
OK, probably need to replace the processor but as a stop gap measure to facilitate necessary revisions, I setup programming terminal remotely via RSLinx Gateway. I was able to get on-line, made my revisions, uploaded backups, etc.
Now I cannot get to the processor via the RSLinx Gateway (Processor shown with Red X)....however the local HMI is still communicating, we are still collecting data and controlling equipment. No configuration has changed since my last revision.
Just wanted to get some feedback on this....it is an old processor that has been in operation with only minor code revisions for several years. I'm sure if I cycle power I could once again access the processor remotely.
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
537
Good day, I have an issue between an M340 PLC and a PRA 0100. The problem is as follows: I have a communication link between the PLC and the PRA...
834
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,283
This is the problem, I need to solve it using a ladder diagram: Write a table of inputs and outputs and propose a control solution for a screw...
22
3,973
I am trying to use my Beckhoff PLC to send emails. I am using a Gmail account that I just created. Apparently Google has removed “Less Secured...
1,148
