AB PLCs communication task
Apr 2016
Rawalpindi
Dear All,
I want to know how to communicate to AB PLCs located in different areas of plant. What hardware will be required like Fiber Optic Cable and converter or ethernet devices. How to setup PLCs to communicate with each other?
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
308
How to Communicate Allen Brandly PLC and S7 1500 PLC? Do I need extra Hardware ? How ?
1,018
hello everyone, I have 2 PLCs controller : Micro850, and 1 HMI PV800. I use CCW to write the program. I already finished programing for both PLCs...
1,449
Hi all, I have two PLCs, M251 of SE, reading data from the same device. One is reading via modbus 485, other one via tcp. I now want the rtu plc...
1,071
I'm on the hunt for for a "Balance of Plant" PLC (or alternative) that is capable of exchanging (sending and receiving) a small number of bit...
2,179
