AB Powerflex question
jmaty23
Mar 2009
New York
49
My production plant uses mostly Allen Bradley Powerflex drives. Every once in a while we have a VFD that goes bad. Usually it just doesn't power up. Has anyone ever had this problem before? Has anyone ever repaired these?
Yes, we have had about 10 units do the same thing.We found out later, after throwing the first 8 away that there was a known defect with some of the units and A/B will replace them through your distributor.(do a search on A/B's site to find the information)
If the failed units are within warranty, I surely would sent them back to AB for replacement. If not within warranty, the general rule today is that drives 480V 50hp and smaller are not repairable except for easily replaced items like keypads and maybe an IO card. At 230V, that would be 25hp.
I know, it seems ridiculous but, the way they are assembled, there is no practical way to get them apart for repair.
Hi, I'm looking to see if there is a solution for an application I'm attempting. I have a PF525 running a pump. It is primarily hard-wired...
1,570
Good morning, I've had an inverter fail with firmware revision 5.002, the only spare is Rev 7.001, when updating the project with the new...
1,268
Hi all. Having a problem with a PF 525 TermBlk 5 input. I came across the drive the other day and not sure how its running. Both the Enable...
2,175
I'm sure someone out there is a lot smarter than I, so here is the question. I have a PowerFlex drive the max. overcurrent is set at 6.0 amps I...
4,982
Hi all. Having had to change jobs due to the recent Covid stuff has thrown me a curve ball. I write my own software and have played with Rockwell...
1,437
