AB SLC serial cable?
imloggedin
Dec 2007
Missouri
81
Is the serial RS232 cable you use to connect to a SLC process a special cable? I was told it is, but in the past ive used 2 different cables that were not AB, just normal serial cables and they both worked.
nope nothing special about it other then it will fit in there when the front door is closed.
But I can never remeber if its a strait through cable or a null modem cable.
I'll guess here. If you are connecting a PC/Laptop to a SLC with a serial port (RS232 port ) then use a null modem cable. It does not have to be made by AB.
Some more info and we will not have to guess. What are you connecting the SLC to.
imloggedin said:
Yup connecting laptop (RS-232) to an SLC 5/04
See below for the pin-out. If you are just programming then pins 2,3 and 5 are all thats needed.
Good Morning , I just purchased a Windows 10 Hp Laptop. Of course no serial ports , but 3 USB ports . Need a USB to Serial cable to go to...
20
6,258
I have an Allen Bradley SLC 5/05 in my location and I want to connect it to my PC to configure a new CPU 1747 L552 in its rack. But, the serial...
21
9,278
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
703
Hi guys. I have a system we work on. It's a SLC 5/05 at a battery connected through CH0 to a serial radio to a L61 Control Logix processor...
2,116
Good morning, I’m looking for assistance on what hardware is needed to message from a CompactLogix L3 controller to a SLC 5/03 or 5/04 via serial...
1,332
