AB Stratix 5700 switch: Finding IP configuration
Oct 2020
SACT
Hey guys so I have this switch previously set up by someone else so the ip/gateway/subnet is all put into the switch - port 1 is set up to send that IP to whatever is plugged into it (my laptop for instance) and it connects no problem (can ping the switch using cmd).
If i wanted to figure out what IP/Gateway/Subnet designation is in the switch how do i go about doing so IF port 1 wasnt set up to allow me to automatically obtain the information.
Do you know the ID and password for this device. You should be able to connect to it using Telnet or by means of the webserver embedded on to the Stratix. You just type the IP address in the address bar of your web browser and the login challenge window shall pop-up.
If you do not know the login and password, and if the EtherNet/IP function is enabled (whihc you can verify through the MOD STST LED which should be solid green) then you can try the Molex EtherNet/IP tools freeware.
https://www.molex.com/mx_upload/superfamily/iccc/EtherNet_IPTool.html
Using the first tab you can detect the Stratix. Then select the Stratix if it shows up and going to the TCP/IP object tab you can do a GetAttribute All request and you will get all the IP settings. Sorry it is late in Japan and I am about to end my day so there may be some typos. Hope this helps.
Hi Guys, I have a Stratix 5700 managed switch that will connected to another different network thus: Stratix 1 on 10.50.3.xx >connect through...
117
hello guys. I'm using 5 Stratix 5700 Switches 4 of them make DLR(Device Level Ring) And one of them software version is not matched 15.2(6)E1...
2,301
Gents, I've an Allen Bradley Stratix 5700 full firmware managed switch and need configure some kind of NAT but don't know how to fix this. This...
1,473
Hello, I am at a deadend using Stratix 5700 to connect two subnets together. Needing some fresh eyes. Basically, I have 1 PLC (IP address...
8,156
I have a customer who wants to start using the AB Stratix 5700 Switch (instead of what we now supply them) because of an AB HMI faceplate...
12,148
