AC Current Sensing Using PLC
khansaab21
Mar 2011
Karachi, Pakistan
Hi there, I am new to this forum and a guy in need.
My current project involves temperature and AC current sensing while temperature is to be displayed on 7 segment displays. 3 displays will be used (temperature resolution of 1 deg is more than enough). Plus, a valve is to be operated proportional to load demand (current drawn by the load). And all of this is being done from a PLC, most probably it would be a very basic one from Fatek having 2 analog inputs, one analog output, 8 digital inputs and 8 digital outputs.
I dont have any thermocouple, 7 segment or AC current sensing add on modules for PLC.
For temperature sensing, I am using a Temperature Transmitter for thermocouples.
I need help for making the display panel and AC current sensing. Is using 3 multiplexed BCD-to-7 Segment Decoder a good idea? (That ll require 7 DO's)
Secondly, I need help for AC current sensing. Sensor is a current transformer. Current range is 1-5 A ac. I need a scheme that converts this current in to a 4-20 mA signal that can plugged in to the Analog input.
Thank you..
I would recommend Red Lion AC current display with analog out put options. They are fairly priced and very reliable.
There are a multitude of other brands of devices with 7 segment displays that can convert a CT signal to a DC analog as well as display the value. I would buy a device that does the display and signal conditioning, and let the little PLC alone to do it's control thing, rather than display logic.
http://www.redlion.net/Products/DigitalandAnalog/DigitalPanelMeters/ACCurrent.html
I think most of these may require the separate purchase of the CT.
(Clink links for Automation Direct examples.)
First, look at a Temperature Controller. Input is a Current Transformer with 0-10V output. Controller has universal analog output. Probably not enough I/O for your project.
I'm confused about your inputs. I assume one AC current, and 3 T/C's. How will operator input the setpoint? A touchscreen is best.
The Analog Click has similar specs to the Fatek, but it's not enough for multiple T/C's.
Use a DL06, 4 channel T/C module, 4 channel Analog Output module, and small LCD touchscreen. Use type K thermocouples.
If you prefer a TFT touchscreen, look at this one.
I need to accomplish 2 things at low cost of course: 1) Detect a short and wire it into a sinking plc input I was thinking to wire +24v to the...
2,178
Hello all, hope someone has dealt with this before. We have a large 100hp blower that has a nasty habit of having its belts jump off. Years ago...
16
6,730
Today I was working on my project for school and we were using a power supply with 24V and we accidentally had the current at 0.9A. We heard a pop...
558
Hi all, I have been working on a project that requires me to measure the current across a 90 VDC motor of a medical device (similar to an...
26
1,573
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
677
