In the example I posted, you need to have 6 input boxes on your screen which represent what fan number the operator key (number 1 to 6).
For eg. the operator key in the following order
Input Box 1 - "5"
Input Box 2 - "3"
Input Box 3 - "1"
Input Box 4 - "4"
Input Box 5 - "6"
Input Box 1 - "2"
PLC always run in the same order, - order 1 to 6, but it takes the data from the first input box, if it represent 5, then turn on fan number 5 when you turn on your first output, represented by Fan.[box1], It indirectly represent Fan.5 in this case. As Fan.5 connected to Fan_5 in the ladder, which in the actual output connected to Fan number 5, it runs
And for 2nd output, it turns on fan number 3 as the Second order runs Fan.[box.2] which is actually representing Fan.3.
In the example I only shows 3 fans, but you can easily expand it
Regards
_______
Hi chavak,
I am getting your idea but not completely. Let me explain what I understand from your post.
You mean to say
Input box 1,input box 2,input box 3 ,……..6 are order which are fixed in the program .
We have to enter the number of fan for example
Fan1 – 1 , Fan3 -2 , fan3 -3 ,,,,6.
In that input box which will fix the order.
Input Box 1 - "5" (fan 5)
Input Box 2 - "3" (fan 3)
Input Box 3 - "1" (fan 1)
Input Box 4 - "4" (fan 4)
Input Box 5 - "6" (fan 6)
Input Box 6 - "2" (fan 2)
Am I correct???
The orders will be fixed and based upon the number the fans will operate.
So we have to use compare instruction and run the fans isn’t it ?????
Some what I am getting idea. Next two days are off for me will be back on Sunday.
Before I was totally blind after reading these posts I am getting some idea thank you all guys.
Also I am studying sqi and fifo but I find it difficult to understand, but I will try .
Correct it if I am wrong also I really appreciate all of you for your response and suggestion it helps me lot sorry for my dumbness but I need to learn and become like you experienced professionals .
:site:
