I'm after a quick and effective way to achieve the following with an FX series Mitsubishi:
10 registers, holding a variety of values, one register holding a target figure. Fatest way of identifying WHICH combination of registers will achieve the desired target figure.
This is for a weighing application, so the registers will correspond to weighing hoppers. The relevant hoppers will then be discharged to "drop" the desired target weight.
Any suggestions of example code, or FX instructions best suited to this task would be much appreciated.
Thanks,
Yorkypaul
Thanks,
Yorkypaul
