Add-on instruction import???
jccraig
Jul 2011
eugene
Hello, I'm currently needing to import some add-on instructions to an online processor using RSLogix5000 v16. The instructions were created with v16.
When I right-click the Add-on folder, import & create are both greyed out.
I'm pretty sure I've done this with v17 but can't recall if I ever tried this with v16 online.
Anyone know if v16 supports online imports of Add-on. If so, what am I doing wrong?
Thank you.
Import/Export tools were significantly enhanced in v17, including Program and Routine Partial Import/Export, the new XML format for Project Import/Export, and most importantly for you, runtime import of Routines, Programs, UDTs, and AOIs.
In Version 16, Add-On Instructions must be created in an offline project and the entire project downloaded to the controller.
Ken ...thank you for confirming what I suspected. I've looked around for some document that would have this info but couldn't find any.
I had to refresh my memory with the v17 Release Notes. There's a nice master document in the Knowledgebase that has all the modern (v10+) Release Notes for RSLogix 5000.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/9242/
I did a lot of runtime import work down the road from you at the IP mill in Springfield last fall, and the v17 import features were a major reason that we did widespread upgrades to the installed base of ControlLogix there.
Well Ken, looks like I owe you one! Next time you're in Eugene, shout out and I'll get the first round. Thx again.
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
335
I just imported four add-on instructions (which I believe are Rockwell AOIs), and they appeared to import OK, and I see them in the "tree"...
3,162
please can someone help me how do i add status bits to the add on instruction in studio 5000 thank you
1,492
Hello all, Is there a way to trend tags associated with AOI? Currently the selection is grayed out. The tag is a local tag and it resides in a...
2,163
I have to create a sample mov template in add on instruction.I just want to know the list of tags which is used to create a mov logic instruction...
2,108
