Add-on instruction input with optional capability
sayahfar
Nov 2013
Toronto
Hi All,
I'm a new AB programmer but I have experience in programming with Siemens. I want to use Add-on instruction in AB same as Function Block in Siemens, so that some inputs is not mandatory to write something and in this case it take their defined values. In AB, I found Add-on same as FB except that if you put it as required, so you should assign something to it and if not put it as required, you couldn't assign anything.
Is there any way to have both together?
But in this case I couldn't assign a parameter to it.
I want something like Function Block in Siemens, the assignment of input or output is optional. maybe you use it several times, for first you can assign a tag to parameter but for second one you don't want and it uses the parameter's definition value.
can I have it in AB?
I replied to this post over on mrplc, I'll copy and paste below :)
For inputs, put them as "required". If you don't need that particular input/output, you can just put a "1" or a "0" in the required place:
As for outputs, you have two options that i can think of off the top of my head:
Leave them as not required. If they are required, then copy the output to the relevant tag on the next rung:
Or, leave them as required, and just create a dummy tag that you can assign to the AOI where it's not required:
Hope that helps!
Hello, I have just started programming RS Logix 5000 for Compact logix. Seems quite neat. I have made my own "Add on instruction" without...
2,979
I am new to AOIs, and do not have a processor handy to test my program. I have a couple of simple questions, which I have not been able to find an...
10,213
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
345
please can someone help me how do i add status bits to the add on instruction in studio 5000 thank you
1,494
Hello all, Is there a way to trend tags associated with AOI? Currently the selection is grayed out. The tag is a local tag and it resides in a...
2,176
