additional add one sensor
vpmsarvananr
Sep 2011
singapore
22
Message body
We have a simatic field PG which we use for the s7-300 PLC's.in my process I need additional add one sensor .
Currently my singal goes from sensor to plc below details,
1) Signal from sensor to asi-distribuctor
2) From asi-distribuctor to asi-master
3) From asi-master to plc,
How to add new sensor, any body know the procedure,
Please guide me,
Thank you
Saravanan
Thank you for your reply friend,
I will explain more details for my process.
4 port “asi-distribuctor" available, so already 3 sensor used that port,, one consider standby, so I will plan to use the port, all sensor got own program (that means address),
Now I add 1 sensor and assign one program (address), but unable to get signal from sensor, I checked ladder logic also can’t see the signal,
How to communicate with plc friend
Thank you
Saravanan.
I have an additiona 5pcs 4-Channel AI (1734-IE4C) and 5pcs 4-channel AO (1734-OE4C) in an already working system 1756-L83E controller with bunch...
494
Hi, I'm trying to plan in advance for new equipment in a production plant. I have a 1517-3 processor using Tiaportal V15.1 to programme. I'm...
870
Hi everyone, History: I do troubleshooting and repairs for customers, I bought in 2016 RSlogix 5000 standard(300) when I had to edit an existing...
1,744
All, Quick question. I have a scheme for how I label my own wiring, but do you have a method you follow for labeling someone else's already...
2,471
I have been tasked with adding an additional PLC to an existing Schneider TM221 is fully utilised, setting up communication between two m221s is...
1,658
