dmroeder
Before you mess with anything regarding AdvancedHMI, make sure that you can ping the PLC. If you cannot ping it, then AdvancedHMI will not be able to talk to it.
The driver you will need to use is the EthernetIPforCLX driver. Drop it on the form. Add our control of choice to the form. Enter the address of the tag you want to connect to in the properties of the control. When you run the project, it should connect to the tag.
Issues at this point are usually typos in the tag name, the tag is program scoped (there is a way to do it if this is the case) or you are entering the PLC tag in the wrong field of the object.
What kinds of errors are you getting? What version are you using?
