Advanced HMI
AdvancedHMI does not care whether or not the OS is 32bit or 64bit. The issue must be elsewhere. Can you ping the PLC from the PC running AdvancedHMI?
Yes i have another AdvancedHmi program runing in a diferent pc with same plc but in 32 bits and runs just fine. same program wont communicate in pc with 64 bits
PLC AddressItem Collection Editor
What an awesome application. I'm just beginning play with this app, but have encountered my first problem. I'm trying to create a chart (ChartBySampling) with PLC data. Up to this point I have been able to create gauges and panel meters. Under "PLCAddressItems" it indicates "(Collection), I must be missing something, in the PLCAddressItem Collection Editor I click add and I get the attached screen. What I'm I missing...
Thanks in advance....
Mark
I have not been able to replicate this. Are you using version 3.98t? The ChartBySampling is fairly new, so it's still going through some bug fixes.
For panel mount PCs, I have used quite a few of the ones from www.ivcdisplays.com with XP Embedded. They have proven to be reliable and I have yet find a better price. I have recently installed one of the new NP-8150A with a hard drive and Windows 7. It was a surprisingly responsive unit.
Agreed. We have a custom-built order fulfillment system with close to 100 7" IVC displays and two 15" mobile-mounted IVC displays. After 2+ years in refrigerated temperatures, we have yet to have a hardware issue
I’m new to plc programming and very new to HMIs. So this is what I have done so far: I bought a micrologix 1100, I used bootP to set the up...
17
1,681
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,067
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
946
Having a hard time getting the data received when using BeginReadMultiple. Not the most familiar with the ClxDriver and EthernetIPforCLXCom()...
2,333
I am in search of a non-PC based, non-SCADA based HMI and software that allows the ability to dynamically draw graphical objects on the screen to...
5,050
