AGV data log
Rproduct
May 2004
Telford, england
im looking for a cheap way to log information using a PLC's on mobile agv's. I would like to know the arrival time(to the second) the agv's move over each location along its route for every one of the maximum 52 locations and also the time a start button is operated for eight of the locations. (at eight stations the operators have to start the agv's) And of course which agv it was.
With the above information I hope to highlight bottle necks and record the characteristics of each of the 15 agvs.
The information does not need to realtime it can be collected every time it drives past the home location or at the end of every day.
There is a omron CQM plc on each of the agv's with the first 1000 data memories taken up for the routes on the magnetic track.
i know that an allen bradley would have an internal clock but i'm not sure if this omron does.
i have been looking at systems used in other agv's on the internet but the trend is to have real time radio communication and control over all remote units which is a bit over kill at the moment. not to mention too expensive.
looking forward to a reply
Cheers Chris
I am getting ready to start an AGV project, and as part of this project I want to be able to basically configure recipes for different part #'s as...
1,797
Hi everyone, I got assignment from my boss to develop AGV system using PLC programming. After surf by internet, I got info that i need to have ...
52
22,687
For interfacing between an AGV system and the stationary system an optical datatransmission sensor for handshake during load transfer is used...
1,363
Looking for some help in setting up a ControlLogix program to talk to an Egemin AGV using TCP? I am looking for some sample code to get me...
2,009
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
57
