Allen Bradley power supply series substitute
JoeTauser
Apr 2006
St. Louis, MO
17
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power supplies available on the surplus market.
Is there a significant difference between the B and the D? I'm guessing the D will work, but if someone could chime in I'd appreciate it.
From what I can gather, it's the same voltage input and amperage rating. I also found this on ebay:
I have never had any issues going from a older version (B) to a newer version (D) for any of the AB products, I have had issues going to other way
Hi everyone. I have an issue with an Allen Bradley PLC model 1769-L30ER. This PLC had a previous program with a different IP address but when I...
546
I have several 5069-AENTR adapters in a system. All of the IO is 24VDC. Can I use the same power supply (24VDC) for both SA and MOD power into...
568
Have some equipment that have the micrologix 1400 1766-L32BWA. all of our equipment in the locations have 208-220vac 60 hz power. Was just told we...
1,758
Hi All, I'm having some trouble on determining the total power consumption of the following I/O modules: 1769-OB32,1769-OF8V, 1769- OW16...
2,654
Help! I have a compactlogix 1769-L32E running RSLogix 5000 rev 20.14 that keeps losing the date and time when we cut of the power!!! I have...
2,212
