Altech Terminal Marking
jtn
Jan 2006
Washington
256
I have the phoenix contact Thermomark Card printer, but have a customer that wants me to use their standard Altech terminals. I have not been able to find a phoenix contact terminal marker cross reference that includes altech. Does anyone know what card can be used on Altech terminals?
I've looked into this myself recently. The Altech terminal blocks are actually Conectwell terminals. I ended up requesting samples of the 2.5mm and 4mm wide terminals and just trying the markers we had. The ones that fit the Phoenix 2.5mm and 4mm terminals do work on the Altech/Connectwell blocks. They aren't a perfect fit, but the pitch is correct and the channel is the right shape for the feet to snap into.
This doesn't answer your question, but, back-in-the-day, the panel shop I worked at used ALTEC. For markers, we just used the solid white long marker they sell, and then used EXCEL to print the numbers on paper, which we laminated, and then glued to the white blank material.
Looked really nice, and solved the problem without a terminal marker machine.
may want to hollar at a few distributors for the terminals. I know our distributor for phoneix and weidmueller have printers that work for both and will print your markers for you for a small fee.
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
119
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
235
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
158
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
962
Hi all, i have a panelview plus terminal 2711P-T12W22D9P terminal with different user names and passwords. Everyone seems to know the maintenance...
805
