Analog Control Mitsubishi PLC
Nov 2012
Pretoria
Good day Everyone,
It's the first time for me to use a MITSUBISHI PLC and I am a bit stuck.
I am using a FX3U-80M PLC connected to two FX3U-4AD analog input module and a FX2N-2DA analog output. Can anyone direct me how to program these analog modules? I have read the manuals and apparently I have to use the TO/FROM instruction to read from the buffer memory of the PLC. The software I am using for programming is Gx Works2 version 1.77F structured function block as programming language.
How do I convert the digital signal stored in the buffer to values in the Centigrade scale (*C): analog input? And which value do I write to the buffer: analog output? Do I have to multiply the values before sending them to the buffer?
Can anyone help me with examples if possible?
I am really desperate and need your help!
Kind Regards,
Sonia
A bit late for me tonight
Sorry
Search this site for
Mitsubishi analogue
There are examples already posted
Hello everyone! I am the beginner with PLC's. I have a plc mitsubishi fx5, and i want to control inverter by built-in analog in that plc. I set up...
2,396
253
Hello, I am working with the PLC connected to analog devices such as ball valve or pumps. the PLC is Siemens S7. the analog input module is...
530
I seem to be on here often lately but cant find specifics about my situation I am trying to control the drive using both ethernet and analog(for...
752
Hey Guys, I have a pair of machines that we are converting from potentiometer speed control to PLC control with an analog output card. PLC is a...
3,807
