analog signal conditioner needed
rpoet
Jun 2008
New York, NY
536
Hi All,
I'm on the hunt for an analog signal conditioner that can do the following:
I have a 10k pot joystick that is spring-return-to-center. Thus, it will output approximately 5v when "centered." I need to take that signal and convert it to +/-10v to feed to a Baldor freq. drive for speed/direction control.
Essentially:
A) when the pot reads 10v, I need the signal conditioner to output +10v.
B) when the pot reads 5v, I need the signal conditioner to output 0v.
c)When the pot reads 0v, I need the signal conditioner to output -10v.
I've attached a schematic snippet for reference. I've Googled "signal conditioner" but with the thousands of hits, I'm a little buried, and I'm looking for something I can source pretty quickly. Anyone have a favorite make/model that will do what I need?
Thanks!
-rpoet
I'm not at a computer but I'm pretty sure you can get what you need at api-usa.com. Off the top of my head I think a 4300G can be configured that way.
Use some resistors like 10k and 10 k the middle of them will be +12 volt.
This will be your ground.
As the pot will sweep now from -12 to +12 Volt you have to put some 1k resistors on the endings of it to get 10 Volts max.
Watch the current in your Pot 24 Volts over 12kohm is 2 mA is 0.05 Watt
Hello Everyone, Happy Thursday! I have a system, and 99% of my analog signals are 4-20 ma. I have 4 analog outputs that are 0 - 10V I have 4...
1,434
All, This should be easy but I'm finding it difficult. I have an older OEM piece of equipment that I need to send a 0-5 vdc analog command...
1,937
has anyone used a penny and giles linear position sensor with an EICT signal conditioner module? I am using this combination to send a signal to a...
3,060
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
249
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
293
