Analog Signal Conditioner
celichi
Apr 2008
Greater Toronto Area
415
Hello Everyone, Happy Thursday!
I have a system, and 99% of my analog signals are 4-20 ma.
I have 4 analog outputs that are 0 - 10V
I have 4 analog inputs that are 0 - 10V
I am looking at different MFG of signal conditioners, and trying to find one that works well and is cost effective, more cost effective than having to add combo cards to my L33ER or going to 4 channel V/I cards.
What signal conditioners do you use/like, or am I going about this the wrong way?
Kind regards,
Paul
I use Weidmuller stuff because it returns higher profit on markup and I work in mission critical environments, but when cost is a factor I always look at Automation Direct, they make good stuff and its also cost effective. They also deliver to Canada within two days, and have excellent free support. I'm a big fan of Automation Direct. Take a look at this solution:
https://www.automationdirect.com/ad...ers/high_density_signal_conditioners/sc6-3220
If that's too expensive then check ebay for something made in China, there is a ton of cheap stuff to be had overseas if you can wait a month for it to get here and decipher the documentation.
All, This should be easy but I'm finding it difficult. I have an older OEM piece of equipment that I need to send a 0-5 vdc analog command...
1,937
Hi All, I'm on the hunt for an analog signal conditioner that can do the following: I have a 10k pot joystick that is spring-return-to-center...
4,150
has anyone used a penny and giles linear position sensor with an EICT signal conditioner module? I am using this combination to send a signal to a...
3,060
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
248
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
293
