DirectLogicUser
ok, I'm kinda new at this, I have a linear transducer that is analog out 0 to 10 volt, I have a baldor mircoflex (analog in) that I am going to use to control my servo motor that will move my transducer. anyone know of the best way to do this? I am using an automation direct d0-06 with an analog in and out card.
Any thought???
PID loop
straight logic
Which would be a better way?
I am doing something like a cnc axis, basically you have a demand position from the plc, you have the current position and you have to move to the new position and hold it.
The transducer sends voltage to the plc saying where the axis is. plc sends signal to the microflex to say move forward or reverse ( 0 to 5, 5 to 10). I am going to assume that the closer to 0 or to 10 the faster the drive will turn the motor, (but assume means *ss u me. (ya know)
is this a simple logic program or would it work better as a pid? Anyone have any examples that they care to share?
Thanks in advance
Any thought???
PID loop
straight logic
Thanks in advance
