...and Another Thing...
mjisaacs
May 2005
Morganton, NC
66
I also have a customer that is prepping for AC FLASH compliance. They are installing interfaces for PLC connection on the outside of the cabs. They have only today, involved me in the process. They have purchased 1747-UIC w/ C13 cables and a cabinet mount jack for connection. The problem is, on two machines with SLC 5/01's, the DH485 (RJ45) jack is already used by an AutomationDirect EZ Touch panel. My question is, does AB make a "splitter" (for lack of a better word) for this situation, so I can be connected to the PLC while the HMI remains connected, all via the RJ45 DH485 jack?
Sending command from 1 plc to another via IP address with 2 SLC500s and viewing change on 2nd PLC from computer. I am testing for a job and need...
4,563
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
161
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
249
I am noticing a problem where i am using MOV instruction and writing literal text into source and String datatype in destination. It works fines...
490
