Another 1746-hsce2 card ?
2004sk4
May 2005
Georgia
172
I have a 1746-hsce2 card located in slot 3 slc rack. The plc is a 5/05.
I am needing to read redlion 120 ppr quad encoder The roller it is hooked to is 4.5 inch in diameter which is .11775 inches per pulse or .0098125 ft per pulse. I am needing the encoder to measure ft. I have it wired like this
ENCODER-------HSCE2
red + 24-- vdc+
white A-- a1+
green b-- b1+
black com-- vdc com (also hooked to a1- and b1-)
What is the best setup for the card using this encoder. I am trying to make head or tails of the manual and all i am getting is frustrated. I am not at work so i can't try anything out to see what work and don't.
Any references to manuals or programs would be greatly appreciated.
thanks as always
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
172
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
435
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
250
I am noticing a problem where i am using MOV instruction and writing literal text into source and String datatype in destination. It works fines...
491
I'm not actually in front of the equipment yet, but this is the information that I have been given by a client: ------------ Data from HART...
338
