another conversion problem
Amr Hassan
May 2005
340
when coneverting a program that had a call for the fuction mul:16
the conversion tool created a call for fc 83
when i imported the file in s7 and compiled the source an error appeared that the PLC type is not defined . is there a way to overcome this problem?\
Because of the terminology used I guess you're talking about converting S5 to S7. The mul:16 function block in S5 is needed to multiply two integers because S5-100U and 115U cannot do this directly. The S7-300/400 can. Simply replace the mul:16 call by a integer multiply instruction. You should look in the help files, because I don't know what representation you're using.
Kind regards,
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
58
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
180
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
444
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
253
I am noticing a problem where i am using MOV instruction and writing literal text into source and String datatype in destination. It works fines...
494
