Another PLC Programme Question.
tbones
May 2014
London
Can anyone hlep with this? thanks
I have 2 x motors, but only a single START button (normally closed) and a single STOP button (also, normally closed). Every time START button is pressed, an alternate motor must run. When STOP button is pressed, the running motor must stop.
let me guess you are a student, i think?
welcome to the site
Firstly - reconsider the Start button - this must not be a normally closed button - too dangerous
if you have a seperately powered control cct and switch off the circuit breaker
how do you stop the motor from starting accidentally.
(Network #1)
The logic in the first line is good but still not good practice.
I say again - Start buttons should always be Normally open
I'm a novice learning PLC's just wondering why there is a reset (unlatch ) for the #StartOneshot when it is never set (latched )??
Cheers
The output is an OTE behind a oneshot.. normally the bit would stay live till the scan came back around to the rung with the OTE. For the purposes of the ladder, he wants to interrupt this prior...
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
249
hi guys, i need 2 diffirent brands to report to each other the first is a AB Micro850 with 2080-OF2 for 4-20Ma output the second is Clickplc...
1,352
MY PLC has only discreet inputs cards currently. Thermocouple Input card for CompactLogix is $1500 bucks and I am not sure if it is even...
3,175
I need one PLC to receive a signal from another PLC. Can I wire the PLC output of one PLC to the input of another PLC? (same voltage of...
3,941
