Anti tie down palm buttons
Kroz said:
Why would you want to use one timer? When it comes to safety, wouldn't you want to use two for double redundancy?
Why? Because you could put as many timers you want to in the PLC logic and still never call it redundant. If the safety requirements are for the use of an ANTI-TIE down circuit, then we wouldn't be talking about plc code.
I am wondering if Paul Rupert and Jessica are in the same class?
I think one of them should tell their teacher that they are NOT going to try & program anything so silly and unrealistic.
If one of these students do end up as a programming engineer their experience in this class will set dangerous precedents for them to follow - "My Professor said to program a stamping press with 2-hand controls using a common PLC and only 1 timer" wont hold up under any OSHA investigation of the impending double amputation inquiry.
It is a fine excercise. Like Ron said, it is not always about safety. Second, two hand control is only marginally safer than a single button. If you are relying on that alone for safety, you will have trouble on you hands.
Original question:
Is there away to program palm buttons using
only one timer in the anti tie down ??
Answer: Yes, several versions have been shown.
I want to know where it was stated this was a "press" of any kind? We all understand what assume means?
I stated before and will state again..."The use of palm buttons or 2 hand control does not always imply a safety issue."
rsdoran said:
Original question:
Thanks..........I was beginning to think I was the only one that noticed this.
And Elevmike the only problem with your original code is that the run coil will strobe everytime the timer times out.......
Dave
Dave,
If you will notice, my post here is a screen shot from DirectSoft. In and effort to avoid severe embarassment, I tested the code before I posted it. The N/C contact just before the timer prevents the timer from comming on to drop the RUN coil.
I understand what your looking at though.. And thats why Tim's code here is a cleaner version. Dispite my best efforts Tim embarassed me a little, but I'll get over it in a few weeks.
Mike
Good day all. I have a machine to automate. It is a 2-ton heat press. It moulds small plastic parts. The mould cycle is initiated after the...
3,088
I searched and could not find an answer. The machine is a pneumatic press,two cylinders 32mm bore. Can this machine be built per OSHA safety...
3,740
Hello, I am in school learning about PLC and RLL and my professor gave us an assignment to try to figure out how to write code for a anti tie down...
85
30,056
Can someone show me an example of an anti tie down program? I am using micrologix 1200.
5,733
I am setting up an educational work cell in my University's automation lab. It is a senior thesis project and will be used for educational...
28
8,674
