Anti tie down
Anti-tie downs (safety device) should not generally be implemented with a PLC (PLC is not fail safe) - however there are rare situations where this can be done safely if all of the required safety conditions are handled by other fail safe devices.
I hope I don't come off as being harsh, that is certianly not my intent, but I think this needs to be said: The implementation of an anti-tie down in ladder logic is very simple. So simple in fact that if it is not being grasped I fear that there are other critical safety issues that are not being dealt with - and that makes me very hesitant to post a solution.
Safety is not something to be triffled with.
There is an article here which will be informative. Again, if you don't get this, dont do it. You can be held personally repsonsible if someone gets hurt.
Good day all. I have a machine to automate. It is a 2-ton heat press. It moulds small plastic parts. The mould cycle is initiated after the...
3,088
I searched and could not find an answer. The machine is a pneumatic press,two cylinders 32mm bore. Can this machine be built per OSHA safety...
3,739
Hello, I am in school learning about PLC and RLL and my professor gave us an assignment to try to figure out how to write code for a anti tie down...
85
30,054
I am setting up an educational work cell in my University's automation lab. It is a senior thesis project and will be used for educational...
28
8,674
Is there away to program palm buttons using only one timer in the anti tie down ??
36
18,325
