Any Idea
Well I assume it belongs to who ever owns the plant that it is in........
Sorry... I think I am funny.
Hey Old Dudes!! Help him out......
:p
That looks suspiciously similar to a variant of an old Motorola VME system.
If you are able to a) show the entire rack assembly and/or b) power down and pull the left-most card and take a picture we would probably be able to tell for sure.
Control systems without brand names or model numbers are just so fascinating to me, coming from A-B where we never skipped an opportunity to paint an octagon on something.
There's a contrast knob; where's the display ?
Can't be particularly modular if the analog input selectors are on the CPU module.
The top and bottom screws are VME-like, but all the VME modules I've ever seen are narrower and have those characteristic pull knobs at the top and bottom.
Any context about the application and location ?
Since there is no brand name, logo or type no, then maybe this is a machine manufacturers custom controller.
Also, the 15 and 5 channels per module instead of the typical 8, 16 or 32 channels. Thats weird.
Has the hardware availability crisis really hit that hard, that this is your last resort for your new automation project?
Due to Murphy's law I am sure this goes:
1. power down
2. pull out module
3. write down name of company that does not exist any more
4. reinsert module
5. power up
6. machine does not run any more
7. you get the blame for that
Check electrical drawing, BOM, event project documents, any manuals, or cable names, small part names. And ask an old employee about who came into the plant to install it.
Not all VME systems used the captive screw system, I have run across a couple of manufacturers that used their own face plates and double width installations, usually to make room for daughter boards.
The comment about Murphy's law is probably worth taking to heart, especially with the battery light llt up. I didn't think that one through.
It would still be really helpful to get some more pictures though, and perhaps a description of the machine itself.
Yeah and it'll go like this: One can't replace the battery (if and when one finds out where it is and what kind it is) without powering down, and then we lose the program which is irreplaceable. Just sayin'.
AB SLCs are like this. The rest off the PLCs have batteries front and center that you can change runnning. SLCs? no! You have to remove the processor card to change the battery. AB says you have 30 minutes after power down to swap batteries, but I don't trust them, no sir. I always upload the program before battery switch.
CPU OK.. Light On.
Run.. Light On
Force.. Light Off
Battery.. Light On.
We can guess the battery is okay.. or at least connected and lying that its okay.
Something that old looking.. take the latter as the better possibility.
I am trying to create an agnostic product queue builder using PLC ladder logic. I have a pallet conveyor and would like to be able to use a NO or...
18
2,226
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,882
I asked this question briefly in my previous post long post, I'm asking again here as the main point so it doesn't get buried. I am pretty new at...
1,519
Everything worked fine until a program file was put in a box from another country, then I used it to fill in the gaps in the program, on my...
1,015
I got involved with Modicon when we were asked to make motion controllers for the old 984 PLCs. Back then the programming was done using Modsoft...
2,510
