Any suggestion of servo motor?
Tofo
May 2013
CA
57
Dear all,
I need a 100-200W servo motor. I need to put the motor and all control components in a volume about 1 cubic foot, I also need to put a small PLC with HMI into that 1 cubic foot volume. To my knowledge each servo motor has a controller, the controller takes quite a lot of space in my case. I hope that my knowledge is not right. Does any servo motor with build in controller?
I use a lot of Animatics SmartMotors. They fit into your power range and integrate the controller, encoder, and motor into a single package.
SmartMotors have a powerful onboard control language, but I don't consider them a "PLC" in the traditional sense.
Red Lion HMIs have a SmartMotor driver !
What exactly do you need this servo to do ? What sort of power inputs can you have ?
Beckhoff has an IO terminal that has the servo drive integrated. They had done the same with a stepper motor drive. I have never used the servo terminal, but used many of the stepper terminals. They save a lot of space and wiring time.
SEW Eurodrive has it's own PLC which plugs into the Inverter. So the PLC does not occupy any space. MoviPLC comes with 8 select-able IO's and the inverter has 8 in and 5 out. You can add more on Can Bus.
You can use their DOP HMI along with the Inverter. They have tiny servo motors as well.
Hey guys this site is an awesome blessing for me. I am trying to get back up to speed with PLC program and I have finally decided on a home...
18
7,969
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
140
Dear Experts , I have a system which contains 10 PLCs (1214C CPU) each PLC with GSM module (Teltonika RUT955) and 2 SCADA PCs at different...
829
Hello all, Can you guys share what has worked well for you in your projects on how to present IO list? Currently I just do an excel workbook...
1,263
Hello all. I am looking for a very inexpensive PLC in HMI for a very basic control scheme..... a couple of discrete inputs and outputs with a...
18
5,724
