Ao 0-24v
what do you want to use it for?
What Amperage?
Is the Analog changing regularly ie has a hertz waveform on it?
Control a 24VDC motor?
Hi Karsten
The supply is rated til 11-30 V
The signal is:
Neutral = 0.5*supply in V
A port 100 % = 0.25*supply V
B port 100 % = 0.75*supply V
Look on page 34 to see the movements of the valve.
Supply on 12V and the analog control on 0-10V
Remenber the signal current is 0.75A
the solution with using a mA output is good possible on your wago units.
i can not see if you are using the electronic version or the coils direct.
if you use direct coils (PVHC) you can use PWM outputs. they should have 1 Amp output. 750-636 it is a DC motor output.with a simple trick you can use this for both directions just add two diodes to the coils.
If you do have the electronics (PVEO or PVEM) of the valves the current is under 1 mA. this can be done with a pwm output with low current like the 750-511. this has 24 Volt max.
I am replacing a 1756-OB16E 16 point 10-31 V DC card with the above card in a 16 slot Rack with a 1756-L71 control Logix 5570 controller. The...
557
Hi, I've bought this PLC + HMI from Aliexpress, the one on the right that uses SSRs. and want to connect a 24V/0.2A DC fan to the output. My...
32
7,164
Hi Everyone, Is it Possible to downgrade to Program from version 32 to 24version..? Because I have 24 version and the program which I am going to...
1,110
Please laugh… but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
1,285
Hello, There was a mix up in information on some redeployed equipment and two of the micro 1400's that came in were hooked to 120v when they...
1,981
