Aop- add on profile for studio 5000
sinanmoral
Apr 2020
Istanbul
52
Hello,
I just installed Studio 5000 V34 and when I try to create the project (with Compact logix Cpu), I get the below picture error message.
I already downloaded and installed AOP from ab.com but the result is same.
There are only 1756 CPUs and modules that I can create on studio 5000 without problem.
Even I installed thirt party product AOP(Mettler Toledo),I can not find this module, also I can not see powerflex 525 drivers.(I already dowloaded it and installed)
Please look at below picture.
What you will see depends on where you are trying to add the device. If I right-click on the backplane and add a module I will only see options for modules that plug into the 1756 backplane. If you have a device like the PowerFlex that connects over Ethernet, then you need to have an Ethernet module in the chassis and then you can add the Ethernet devices under that module.
OG
Edit: My software version is older so it looks a little different.
Thank you very much.
As you said, after inslalling ethernet module to backplane,I can add powerflex or third party device (Mettler toledo) and my one problem is solved.
How about compact logix issue, Why I can not create the project on studio 5000.
I get error message as '' Failed to create the project. Module profile could not be found.This could indicate the module profile is not installed'' (picture is above post)
Compactlogix model 1769 L18ERM B1BB that i wanna create.
Thanks in advance.
I think you have to install the right firmware package to your Logix Designer, otherwise Logix Designer does not have the right compiler for the CPU you need. You need to be registered in the Rockwell web portal and download the desired firmware package.
thanks for your reply.
I have multi version Studio 5000 and Rslogix 5000 V20.
Problem is still ongoing.
CPU model that I wanna work on; 1769 L18ERM BB1B.
When I try to create the project with both studio 5000 and rslogix 5000, I get error message module profile can not found like below picture.
Any other advice?
Thanks in advance for your solution.
Any other advice?
any Update about this one?
i face same issue.......
I am looking for an AOP to pass data to a Motoman DX200. Anyone have experience on passing data to the DX200? 🤞🏻 Don
3,504
Word of warning. I had issues with a 5069-AENTR not appearing in IO selection. After downloading the latest version 40 AOP, still didn't appear...
147
When i try to open the properties of a 753 drive, i get a fatal error and logix crashes. However, I can open the same AOP on V31 and it works...
792
So I've been looking at the documentation, and I'm a bit uncertain about the data for the AOPs on these AB drives in general. I don't have the...
1,271
Can an AOP be removed from Logix? I seem to have some version weirdness from an E&H AOP and I need to see if reinstalling the AOP will correct it.
982
