.apa not valid
I can just restore this from the thumb drive right?
I should not need to install the files any where else.
Just go to Application manager and select SE (Local) > Restore application > then browse to where the .apa file is on my thumb drive double click it and say next.
I only get .apa is not valid for some reason.
I know I have don't this in the past and don't think I did it any different than now, but I am certainly getting a different result.
Thanks for taking a look and confirming the .apa does work, at least I can rule that out.
BCS
Have you tried copying the .apa file to your desktop and trying to restore it from there.
I know I have had problems before restoring from a flash drive.
I have also had instances where I couldn't restore at all once I had copied the .apa file to a flash drive.
Cheers
Mark
is 1 computer 32 bit and the other 64bit? Somewhere I seem to remember that being an issue with the database.
If you have the .mer (runtime file), try restoring it through the application manager.
I have struggled with the application corrupting (your issue may be different). One thing I found helped was to be logged into my computer with admin rights.
Cheers
Mark
I did not try from the desktop but did try several time after moving the file into my C drive.
Just getting back on shift this morning so may poke at it a bit more after coffee.
Strange that Robo77 could open it right up after I emailed it to him, but I am unable.
(But I can open other applications just not anything I am pulling from another PC and trying to transfer to my laptop)
Thanks,
BCS
I don't believe so, my laptop is 32 bit and the other PC is just a small form factor unit, have never had compatibility issues before.
I think we have been pretty careful to keep everything 32 bit up to this point.
Times are a changing soon though I am sure. :)
I will double check on that though.
Thanks,
BCS
It is an SE project not a ME project. :)
I have full Admin rights to the laptop and never let IT touch it.
BCS
Hi Guys, I have an apa file received from my colleague and his machine is dead on which he developed the FactoryTalk view application. I cannot...
21
4,797
Hi all. I have read a bunch of posts on the forum over the years on the "invalid archive apa" problem, including...
2,281
Good Morning Everyone, I know this question has been asked many times on this forum but honestly, I couldn't find the answer. So I have .apa...
1,510
Hi - trying to "restore" application using Application Manager on a machine running FTView SE Client, v6.1. When doing so, I am getting a ".apa...
2,401
I recently tried to put a Factory Talk View file onto my computer and the message comes up with: “.apa is not a valid archive file.” Has anyone...
4,306
