Invalid apa file FactoryTalk
host machine: FTView SE V8.00.00, Win10 Pro 64
RA test / VM: FTView Studio V8.10.00, Win 10 Pro 64
Does not having FTView SE on the test machine causing my problem? i was under hte impression that as long as i had studio, i could open the file and even test view it for up to 2 hours... will that not work here?
I'll have to defer to the experts here, I have never used SE. Look at the extracted application, the APA appears to be for SE, not ME.
Is your version 8.00.00 system a 32bit OS?
If it is, I believe you will NOT be able to restore it with a 64bit OS because of incompatible tag databases.
afaik this applies only to version 6 and earlier. In version 6.1 and later both 32 and 64-bit applications used the newer tag database.
What is your "Goal" for FTV SE on the laptop?
The reason I ask is there are several option for an SE application install.
The three options are 1. View SE (Network Distributed), 2. View SE (Network Station), 3. View SE (Local Station)
the main goal is to migrate the archive over and make sure i understand the process, before we remove the old PC. once the new PC is up, i will set up VMware with win10x64 and then do a FTV install, and then load the archive.
i just want to make sure it will work for me and i understand the process/steps needed to do it.
Hi all. I have read a bunch of posts on the forum over the years on the "invalid archive apa" problem, including...
2,281
Hi, I'm trying to add ethernet modules to one of our plcs, but I get about 15 errors that say "Invalid Signature. Reseal instruction to resolve."...
323
Hello, Im new to Studio 5000 View Designer and i try to make a popup reusable screen. So i create a user-defined screen with 2...
250
Hi, I'm setting up a new cell with a Fanuc R30iB and Compact Guardlogix 5380 PLC. I have gone through my robot setup as usual, but have not...
730
Hello everyone, been trying to figure this one out for awhile now. The system configuration is as follows: Processor is an L63 5563 ControlLogix...
612
