Armorblock communications
wperriman
Nov 2012
Ontario
25
I'm installing a system with 7 Armorblock modules, 1732-16CFGM12R. They are connected to a Compactlogix 5336 controller and I cannot figure out how to read a communication failure between them. In the module configuration I see that I can set the processor to fault out if the connection fails but it seems like there should be a way to set an HMI warning that the connection has failed without faulting the processor, I just can't figure out how to read the fault. If anyone has configured these and can point me in the right direction that would be great.
I use a general-purpose connection monitoring method based on the Get System Variable (GSV) instruction and the EntryStatus attribute of the Module Object.
This is common enough that there's a little Programming Manual dedicated to similar aspects of Logix 5000 programming: Logix 5000 Major, Minor, and I/O Faults Programming Manual, 1756-PM014 [Direct Link].
You will also find quite a few discussions of the topic here on the Forum if you search "GSV Entry Status".
Hello all, I have a 1732ES-IB16 Series A block that I have set the IP address on. I am unable to disable bootp using any method. I have tried...
352
Hello, I am stuck on trying to get an ArmorBlock, 1732E-16CFGM12QCR to respond to EIP outputs. My PLC is Panasonic FP0H-C32ET. I Registered the...
142
I am having trouble accessing the embedded web server of my 1732E-IF4M12R module. My digital modules accept the password fine, but the analog...
1,627
I am getting ready to use an ArmorBlock I/O module for the first time. All I have done so far is connect power to it. When I apply power it goes...
2,649
ArmorBlock 2-Port EtherNet/IP Module I am working on starting a plant up and we have a tremendous amount of these modules as the plant was...
2,544
