ask for suggestions
Lil Saleh
Dec 2016
Damascus
Dear friends
If we have line production and this line has automation system with SCADA.
and we want to make the owner to monitor some of the parameter and status from a room about 500 m distance from the control room.
we want to make small project in wincc differs of the original project.
what is the best way to do this.
Thank you
Is the 500 m in "Line of Sight"? If so, and this is all you want to do!!! I would probably setup a wireless bridge between the 2 endpoints. (This equipment will cost about $200.00 USD) for the pair. This equipment can be programmed to only communicate with each other at the "MAC" level so hacking would be almost impossible.
Once the network has been extended, you can do anything you need just as if you was in the same building.
Simple, cost effective!!
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
974
We are to develop a first application in Codesys. It will contain motion (Softmotion) with drives on Ethercat (CSP mode). Off course there will be...
918
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
830
Hi guys.. I am using Vijeo Citect 7.4.. I am doing a function inside a function.. What I want to do is I want to put a function to sleep but want...
1,442
I am working with a 1768-ENBT and I was able to connect to it through my laptop. My laptop IP is 192.168.1.10 subnet 255.255.255.0 and the PLC...
1,580
