(Ask) please help me about PLC
recca_mishima
Feb 2014
Karawang
I once read in one forum that Ab PLC can connect to Visual Basic, to create HMI. I would like to ask, the first step, I have to do what? Then I have to do? Please guidance.
There I did not find how to set the communication between the SLC to VB, some people say its RSlink settinglah in, but I do not know how .. I ask guidance and assistance
Well, you need a driver or write one yourself. This is not a trivial project and my recommendation is always to use off the shelf software unless you are a good low level language programmer or just for a hobby project.
The link that jag posted is exactly what you are after. It's a Visual Basic based HMI package that will connect to your SLC. The drivers are included in it, so Linx is not needed.
That thread should get you the information you need. It includes a link to SourceForge for download and a video. There is a ton of information in that thread.
Basically you have to download VB.NET Express from Microsoft, download AdvancedHMI, follow the quickstart guide that comes with it. If you have any specific questions once you have made an attempt, post back...
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,017
We are to develop a first application in Codesys. It will contain motion (Softmotion) with drives on Ethercat (CSP mode). Off course there will be...
935
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
870
Hi guys.. I am using Vijeo Citect 7.4.. I am doing a function inside a function.. What I want to do is I want to put a function to sleep but want...
1,452
I am working with a 1768-ENBT and I was able to connect to it through my laptop. My laptop IP is 192.168.1.10 subnet 255.255.255.0 and the PLC...
1,607
