Authorizeing Step 7
NoName
Sep 2003
Domžale
273
Hello ppl.
I want to know if there is a way to authorize Step7 without a floopy disk on the comuter. I tried to map a network floopy drive but then I when I tryed to install Step7 I couldn't select the maped network floopy.
Is there another way???? Please help me!
USB floppy works well.
There should also be a way to move authorisations without the floppy and without any physical link between the computers.
It requires you to generate an authorisation code on the computer from where you want to remove the authorisatiom, and then use the code on the computer where you want to put the authorisation.
Have never tried it though. Its described in the online help in the AuthorsW utility.
When you install authorsW on a networked PC with a fdd and move the autorisation to its harddisk, you can move it afterwards to any other computer's harddisk on the network.
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
203
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
264
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
356
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
565
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
705
