Automatically Decel a 700H vfd with pressure setting
remullis
Oct 2012
Georgia
179
I have a need to temporarily decel a pump vfd when the head pressure reaches a certain psi. The application is pumping a slurry through sprayers that clog from time to time. Any pressure over 525 psi blows the pump diaphragm.
We monitor this pressure in logic so I know I could cut the pump off at this pressure however I need to pump to continue at a lower speed until we unplug the sprayers. Can this be done using the .spdcmd of the vfd and if so how would I go about programming this in logix.
The drive is a 700h with rslogix 5000.
I'm using FactoryTalk ME version 13. I have an alarm banner that is an on top display. Whenever there is an alarm this banner becomes visible to...
903
I have a PowerFlex 40 drive that communicates with a 1756-L61 PLC via an 22-COMM-E card. There's an auxiliary contactor attached to the motor...
1,803
Hi All, I had to replace one of my drives(SIEMENS G120C) in my conveyor system. the problem I'm having is the motor is running fine in manual...
1,237
Hello Gents, I have got a request to stop the system at fixed times through the day (at End of Day/Night shifts) which could be done using the...
935
Hello, I am hoping to find a way to tell FBD not to automatically create a new tag once the AOI or any tag is copied. Is this possible? For...
941
