Automation Direct to InTouch...help
arrowpilot
Dec 2003
PA
34
Greetings,
Using AD for the first time and I need to integrate a controller into InTouch. Have an H2-ECOM ethernet module and I was planning to use KEPDirect as on OPC link between the two.
Alas, KEP is not yet WIN7 ready!
Any other advice or solutions for making this work?
I thought about trying to setup my ECOM for Modbus TCP and then using Wonderware's MBENET driver to connect. Does that sound promising??
Thanks in advance for any and all advice.
Mike
Hello,
PeakHMI has an AD driver and an included OPC DA server. As well as other parts. ;)
You can download the demo from here and see if it works for you.
Automation Direct now has a version of KEPDirect that is Vista compliant and runs well on Windows 7 OS's. It is the same Version 5 server the Kepware has been shipping. They have been shipping for about a month. Contact them for an upgrade path.
Greetings,
Mike
you will want to use the dasmbtcp driver instead.
Thanks for the info. I contacted AD tech support about a week ago and was told they are waiting for a Win7 version...
I will try them again.
ANd while I wait I may just try the DAS driver suggested by diat150...that may be my least expensive option.
Thx for the suggestions guys.
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
131
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
139
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
572
Anyone tried Automation Directs new CM5 HMI. We've been the EA9's for a few years now with minimal complaints. A few failures here and there but...
17
1,597
I'm using an Automation Direct GS20 VFD for the first time and I have a question for the Automation Direct gurus regarding the recommendation of a...
1,104
