Automation Studio 2.7.0 Visualization project to HMI
aress124
May 2022
Wrocław
I would like to prepare a project for the operator panel and I do it like this:
New project -> I choose the appropriate panel, it seems to me that the visualization is created automatically.
I want to build it and put it on the card, but I'm getting errors.
Can anyone help me how to properly complete such a project?
Errors:
Code:
* Compiling arconfig ...
* Compiling arconfig ok
* Compiling ashwd ...
* Compiling ashwd ok
* Compiling asfw ...
* Compiling asfw ok
* Compiling a ...
a:(0) :Starting Project Analyser...
a:(0) : * [BR.VC.ProjectParser] warning level is [3]
a:(0) :
a:(ProjectParser) :Error: 7004:Pobranie fabryki klasy COM dla składnika o identyfikatorze CLSID {54347BFE-9052-4FB1-AA5B-7C853732828F} nie powiodło się z powodu następującego błędu: 80040154.
a:(0) :   w BR.VC.ProjectParser.ProjectParser.Main(String[] args)
a:(0) :
a:(0) :Failed
a:(make.exe[1]) :Error:  *** [all] Error 1
a:(make.exe) :Error:  *** [all] Error 2
* Compiling iomap ...
* Compiling iomap ok
3 Error(s) - 0 Warning(s)
Indeed, I have a 64-bit system and the program is quite old and may need a 32-bit system. Thank you.
But apart from that I have 2 more errors, I wonder if they are related to the first error:
It could well be, I would try to get rid of the error regarding the com issue, if there is another then work on that one.
It is possible that the two errors are the conclusion so in fact could only be one problem but throwing 2 errors.
Hi, I would like to prepare a project for the operator panel and I do it like this: New project -> I choose the appropriate panel -> add object ->...
471
hey all, when adding a new visualization to your project in Automation Studio 4.0 you get your choice of templates. i was wondering if anyone...
1,977
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
639
Hello Experts, I recently stumbled with an issue about ABB VFD ACS800 connected with B&R PLC X20CP1484-1. This ABB VFD ACS800 somehow got...
341
Hi all, I am working with an IO link sensor (measuring current across motor)and need to read in and store the sensor values for 5 seconds, then...
1,265
