Aveva System Platform - propagate template changes to child
ASF
Jun 2012
Australia
3,921
Hi all,
Another (hopefully basic) Wonderware question.
Once again, I have a template called, say, $Tank. $Tank has an attribute Number (integer).
I also have templates called $Motor, $Valve and $Sensor
I created derived templates of $Motor, $Valve and $Sensor and dragged them into the $Tank template. Inside the $Tank template I renamed them to Agitator, InletValve and LevelSensor. Then I created 100 instances of $Tank. So far, so good.
Now I want to add another $Motor to my $Tank template, so I create another derived template, rename it to DischargePump, and drag it into the $Tank template in the template toolbox. This all works fine. However, the existing instances of the $Tank template do not automatically acquire the new DischargePump element, even after saving and checking in the template.
What's the missing piece here?
It's been a while since I've touched an actual system platform system that wasn't just Archestra graphics in ol' Intouch...
Have you tried undeploying the already deployed tank objects, then re-deploying?
That’s not the way archestra works.
New attributes will be propagated, but when you are doing what you have done only new instances of $Tabk will have all contained objects.
You might be able to import & maintain the same hierarchy though
I've tried undeploying and re-deploying, yes.
@lostcontrol so how do I get new objects to propagate? Do I just drag them from the template toolbox into each instance?
Objects or attributes?
Pretty much... Create the new object from the new object template, then drag into the container & rename accordingly.
Note:
attributes inside objects will automatically be added, but objects contained within objects/model etc will not unfortunately..
Got it, thanks. Create new child instance, rename instance, drag to existing parent instance.
Hi all, I had to restore a few days old backup for my GRnode and when I try to undeploy/deploy some of the instances, I get this message: Error...
4,141
Hi everyone, I am new here, I am working in a project where SCADA Data need to upload(insert in to) Database table in real-time, I am Using AVEVA...
1,207
Seems odd that you can make a symbol and place many of them but if the text on a button and or elsewhere in the symbol comes from a Custom...
1,644
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
91
Hello guys, I would need some help. I have installed the aveva plant scada and want to run a project. From the configurator, all are fine, as I...
116
