B&R ipc 5000 boot fail
ahmedhekal
Apr 2023
alexandria
i have B&R ipc 5000 which is failing at booting the windows xp , it runs on 512 mb CF card
how can i fix this .. is there any solution
to fix the windows or run the ipc somehow ?
Hi
you can try to copy the CF card. Maybe there is some bad sectors that cause the issue. I am not sure, but maybe on a new CF it could work.
If you have another machine with this CF card, you could copy it from that one alternatively.
Regards
Manfred
Hopefully you have a backup somewhere otherwise you'll probably have to get one from the OEM. If you have a backup download the B&R Runtime Utility Center https://www.br-automation.com/en/downloads/software/automation-netpvi/pvi-development-setup/
I think you can install just the free utility to make/burn images.
You then need to find a compatible CF card. Not all CF cards are interchangeable. I've used Cactus to get a good reliable CF card. https://www.cactus-tech.com/products/industrial-grade/compact-flash/ You can contact them with your specifications and they can help you get the right CF.
Good luck.
good afternoon, Help me, hard disk was removed for the up up error - -- - -- -- -- -- - Award Boot-Block v.1 No Disk - -- -- - -- -- -- -
1,589
Could anyone be having a B&R IPC 5c5000.01 or the flashcard reader for the unit, urgently required.
2,270
172
I want to make traces of variables in a Beckhoff IPC (that is not the engineering pc). Is it so that I should install the Twincat Scope server on...
462
If an IPC with Codesys runtime on it has two separate ethernet ports, is it possible to have an Ethercat master on each of them? I do not find...
555
