Back again with project 2
No dont think so machine is indexing while t4/1 is timing
Yes Steve B3:3/0 is the OTE, not sure why we used an internal bit, but that is what he layed out.
Geez I'm form the other side of the planet and I worked it out...hiccup. 🍺 mind you I personally would prefer something different
you should listen to consys 🍺
it's Molson Genuine Draft
the anti tie down logic above is not quite correct.
the output bit should be used as a seal around NC timer done contact before it...
bryan372002 said:
So is Someone gonna tell Me what MGD is? Terry?
Here is another clue……
Last month, scientists released the results of a recent analysis that revealed the presence of female hormones in beer. Men should take a concerned look at their beer consumption. The theory is that beer contains female hormones (hops contain
phytoestrogens) and that by drinking enough beer, men turn into women.
To test the theory, 100 men drank 8 pints of beer each within a 1 hour period. It was then observed that 100% of the test subjects:
1) Argued over nothing.
2) Refused to apologize when obviously wrong.
3) Gained weight.
4) Talked excessively without making sense.
5) became overly emotional.
6) Couldn't drive.
7) Failed to think rationally
8) Had to sit down while urinating.
No further testing was considered necessary.
Bryan, now that you have the Instructor solution, I suppose it is okay to post my solution. This fits your original instructions of a 3-second timer 1, with an output relay to operate the machine. If the relay was really internal, then there would have to be some additional hidden logic (elsewhere in the program) that controls the actual machine Indexing output.
This solution has the advantage that, if a hand or foot is removed at any time, then the Index function is canceled.
Normally a motor needs an interlock, but the Index function is not exactly a "motor run" output. If the machine is so dangerous that it requires 4 human interface switches, common sense says it probably should not be interlocked (latched on) like your instructor showed. That defeats one reason to have the 4 input switches in the first place. That is to make sure the operator does not release one switch and stick a hand into the machine (if it is latched on for 2 whole seconds).
That Looks Great Lancie, I agree with you, if that matters....lol
I appreciate You taking the time to do this, and I am keeping notes.
The 2nd timers not needed, it could have the first timer, then the 4 n/o in series with output, then the o/p in parallel with the timed contact.
EDIT:
Forget the above, this blurry eye'd engineer just got it.
May i start with good morning noon and night Yes i am back on the project again i am attempting to get a little more involved in programming. I...
41
8,081
When I connect to the site PLCS.NET is checking to see if the connection is secure. I click on a topic and it does it again. Click back and it...
20
1,270
This old chestnut again... Our clocks (UK) went back an hour yesterday. Now the time displayed on the HMI is 1hr behind what it should be. In...
24
2,026
My Lenovo P50 has served me well. it is still working, but I want to get something newer before I can no longer get a laptop w/ windows 10. I was...
23
6,681
Wizards, I have been gone from my plant for a while and upon returning I have two, 480vac-24vdc power supplies on my desk with DEAD written on...
2,274
