Beckhoff IPC and PLC Communication Error
ZhongJiwei
Nov 2013
Singapore
18
Recently always have the communication error between Beckhoff ipc and plc, anyone can help, it is setting problem or hadware probelm,many thanks.
PS: once i loaned a ipc and replace the exiting one,working fine.
Existing IPC is P2P, once the network port was broken and sent back to Germany for repair(the whole motherboard was replaced). so loaned a ipc which is nci from supplier, no comunication error when using the loaned ipc.After replacing the repaired ipc, the problem came.
the comunication between ipc and lc is Ethercat, and both are beckhoff products, how comes this error?
by the way, the ipc before the network port was broken and sent back to Germany, got the same problem as well, but not so frequently.so i suspect that the setting problem in beckhoff system manager, but not for sure, how to confirm it?
just found that this communication error is generated by twincat plc control, in the program, it will use the twincat function block which called:FB_EcGetMasterState, when the boolean variable output bit of state is not equal to 0001, it will triger the communication error, so what is 0001 comes from? thanks.
64
Hi everybody, An IPC connected to a Siemens PLC as a slave module. When I restart the PLC while IPC running then PLC can't find the IPC node on...
9,152
I want to make traces of variables in a Beckhoff IPC (that is not the engineering pc). Is it so that I should install the Twincat Scope server on...
445
Hi Everyone, I have a project involving a Beckhoff IPC with Twincat and a Yaskawa servo motor and drive. I'm trying to use the MC_HOME function...
508
Hi Guys, Just wondering if someone here has used/found an Allen Bradley or any other vendor who have IPC's similar to what Beckhoff currently...
1,857
