Beginer
Jacobplctalk
Apr 2008
Bangalore
Hello,
Could anybody tell me if RS232(9-pin From a PC) network can be connected directly to a RS485 device without the help of a converter.
Sorry for the silly question.
The short answer is NO! The two protocols are different. You can configure a PLC processor for RS232 communication through RSLinx if the processor has an RS232 port and connector, also 9 pin. To use the DH485 connector you must configure your link for DH485 and use a converter that will handle USB to 485, as the old PIC module no longer functions with the latest versions of Windows, you have to use the UIC converter.
Yes..it's possible to have a RS232 to RS485 without a converter...I've used it before on Siemens MM3 drives, drawing is attached.
Note though that this shouldn't be used as a permanent solution.
Once again no. Besides protocol differences found in comm products like RSLinx, there is a big difference in signal voltages and how each responds, 232 is single ended and 422/485 is differential. There are impedance differences as well. The cost of a simple converter can be as low as US$50. Don't waste time trying to get around this difference.
Beginner
Thanks a lot for the reply.
But even now there is a twist to the PDF that was attached. So should I finally come to a conclusion that the answer is No? As the PDF too states that it’s only for Demo purpose and not a permanent solution. So I guess I will come to a conclusion that it is possible but is not the feasible solution.
Absolutely NO. That PDF is a quick and dirty hack, that only works at all because of an oddball configuration of the port on the MicroMaster drive. Honestly, it's just plain stupid that a company like Siemens even demonstrates nonsense like that.
While I agree with this sentiment, I must disagree with your following statement:
rdrast said:
...that only works at all because of an oddball configuration of the port on the Micromaster drive.
This is incorrect and was obviously pure supposition on your part.
This afternoon, as a more generic test (than connecting to a Micromaster 3), I connected this lead to the RS485 side of a RS485/RS232 converter and used the finished assembly to connect 2 PC's together via their serial ports. I ran a terminal program on both PC's and established bi-directional communication immediately.
Beginner
Thanks KRK for the answer. I can understand that you have performed a test on this matter.
So I thank you so much for the answer. I also would thank all the others for the answers that you have provided.
Yes, I was curious as to whether rdrast was correct when he said it was just a peculiarity of the Micromaster RS485 port.
But I'd like to re-iterate that it's just a (handy?) trick and not an engineered solution...you were correct when you said:
probably up to 50' seriously doubt it will work up 1000' yes it will work because it still has a differential voltage change but the rs 232 port does not have the driving current for long distances
The problem is with the signal levels. RS-485/422 are well defined line-driver signal levels. RS-232 is just about completely random, with potentials of up to 25 volts, positive and negative, for a potential 50 volt differential.
I'm just not going to trust mixing signals like that. The devices cost much more than a proper converter.
im trying to learnn step 7 programing im fairly good at ab programing plcs but dont have mutch experience with siemens so my question is about...
1,403
Hi everyone! I just joined this site and I am interested in learning about PLC, I am going back to school to finished a degree in Mechanical Eng...
2,914
Can any one please tell me about learning the PLCs. I am a Mechanical Engineer and have a thorough knowledge for the mechanical systems. I want to...
3,841
Hello i'm a protool beginer and i have to make a school work. the work consist in make the game BATAK, the program in plc is done, and i have to...
2,089
Is or isn't this the right place to ask questions and recieve answers? I will ask again my question I have just received a Mecman IPC 500J...
2,625
