Best Logic for a Flow Split?
Shiro485
Apr 2013
North Haven CT
103
Hey all,
I'm looking for a little advice.
I developed a system with 16 different lines, and a color injection. This mixes all the raw ingredients and injects color.
Customer has decided they would like the addition of a color split, so that we could make two seperate batches.
The split can be anywhere between 0-100% between the two colors.
The split will be modulated with flow control valves at each discharge point.
Im looking for the best practice in determining the split.
I have thought about summing the flow from all active lines flowmeters and then applying the split to that total flow, but I foresee this being a problem upon initial startup.
Or alternatively taking the setpoints for each active line and adding those together and then splitting from there. .
Has anyone done anything similar and might have some advice to impart on me?
Any help is much appreciated.
Thanks!
When I've done similar I take the desired split as a percentage of total. Then I add the total actual flows. The flow setpoint for each path sent to the flow control loops is then the total actual times the desired percent.
Greetings In my project, there are three control valve One of the hot water line with a diameter of 200 Another on the cold water line with a...
3,834
Just want to put the question out to the PLC guru's... What is the best permissive logic for an Allen Bradley PLC MSG logic? I have seen message...
3,379
What do you guys use for a small compact installation? The setup is for just 1 input. A pulse off a scale and then send it to another plc.
20
4,796
Hi Guys, Iam just plain curious. How do u proceed debugging a SLC 500 program which has no descriptors in it? Recently i has to do one and it took...
5,465
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
587
