BootP for SLC505
DairyBoy
Jun 2007
UK
393
Hello.
I'm using bootp to set an ip address for a 1747L551 processor.
The bootp program immediately sees the mac id and I am able to enter an ip address, which is immediately sent to the processor (as displayed in the information window).
At this point the processor can be pinged with its new address.
When I click "Disable bootp" (by button, right click options, or via Tools pull-down) I get the error "Received error message from -mac- [Get_Attribute_Single] [5]"
(The mac is displayed, but I didn't know if it should be put out there).
The processor loses the new ip address when its power is cycled.
Rockwell tech have returned a couple of unrelated tech note links so not much hope there.
Any suggestions welcome, thanks.
its an unfortunate consistent bug.
right click the device in the bottom window and choose disable bootp from that dropdown instead.
ID: BF4486 | Access Levels: Everyone
hopefully that's the issue you're having with it.
Thanks, Ian. I was aware of that bug which is why I've been using all available ways to initiate the disable. Just plugged it in again and bootp can't see it at all this time o_O
power down the device and power it up while its plugged in. some devices don't broadcast continually unless in a window on powerup.
When I use the Rockwell BootP tool to set a static IP address, I don't bother with the disable button, I just get the IP set and then use programming software to perform a download with BootP disabled in the downloaded file. You need to do that before cycling power.
In your case, it could be that you successfully disabled BootP but the tool couldn't confirm that.
It's sorted :)
It took a while but I thought well, if it holds its new ip address until power cycled, then let's see if i can go online in RSlogix. Yes. Into channel config and unchecked that pesky bootp enable :p
OkiePC: You beat me to it!
Hello all, I have a 1732ES-IB16 Series A block that I have set the IP address on. I am unable to disable bootp using any method. I have tried...
367
I am not sure what i am doing wrong laptop ip 192.168.1.233 with subnet mask 255.255.255.0 micro820 ip unknown 1) i connected a micro820 and my...
3,985
I have spent hours trying to search and resolve this, but no luck. With my fairly new laptop running Windows 10 Pro, I cannot use the BootP...
37
27,395
Started at a new job. Trying to bootp a L17er. Bootp will not work at all. Tried other plcs and it will not populate the MAC relation for...
2,799
I just bought a new compact logix 5069-L306ER i am trying to set up the IP address thats working fine but for some dang reason i can not disable...
2,065
